In other words, it's a stuff around to use anything other than TLR rims and tires - hard to seat, hard to seal, leak like a sieve, beads come unseated when deflated, and cannot be reseated without a compressor.
TLR rim profiles maintain a tight enough seal from the inner channel, up and over the humps, all the way to the bead channels, such that air does not as escape as you inflate them. In theory, not always in practice.
Strongly advisable to have a compressor on hand for the initial tire seating. But with a good combo, for initial installation you can inflate them with a hand pump, wait one minute, deflate them very slowly (so that the beads remain locked in the rim), remove the valve core, squirt in sealant, replace valve core, then reinflate. Done and dusted in five minutes, and unlucky if more than a few drops of sealant need to be wiped off.
I agree that fat tire tubeless setup is very forgiving. MTB and gravel tires are easy enough to get on any rim, any old tape will just about do, and sealant eventually gets the job done if you reinflate and rotate the tire every day for a week.
Fifteen years ago that was par for the course. Nowadays, with the plethora of TLR options, I don't see why anyone wouldn't avail themselves of it.
And road tubeless is a different ball game. Narrower the tire and rim, the more difficult everything gets. Any tire below 32mm I think tubeless is not worth the trouble - too high a risk that the tire and rim you choose do not mate well together. Maybe acceptable if you have enough spare time and money to keep trying new tires until you find a suitable one.
